简介
The ThinkPad P51s uses a compact cooling assembly consisting of a single blower-style fan connected to a heat pipe radiator. Over time, dust buildup, worn bearings, or prolonged thermal stress can cause the fan to become noisy, run at full speed constantly, or fail to spin altogether. When the fan can no longer cool the CPU and GPU effectively, the laptop may throttle performance, overheat, or shut down unexpectedly to prevent hardware damage.
Before beginning this repair, shut down the laptop completely, disconnect the AC adapter, and remove the external battery to cut power to the system. The internal fan is located beneath the bottom cover and partially under the heat sink assembly, so some ribbon cables and nearby components must be handled carefully during disassembly. If your fan has seized or is scraping internally, avoid forcing the blades — they can break easily.
This guide will walk you through safely accessing, removing, and replacing the internal cooling fan. For best results, consider cleaning the heatsink fins and reapplying thermal paste if the laptop has severe thermal issues or has not been serviced in several years.
你所需要的
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
另外一个人完成了本指南。
