跳转到主内容
Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement
你所需要的
  1. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove base cover: 步骤 1 中的图像 1,1
    • Remove the 7 screws holding the base cover in place.
    • Remove the base cover.
  2. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Unplug the battery: 步骤 2 中的图像 1,1
    • Peel up the insulated sheet from the battery connector.
    • Unplug the battery connector in the direction showed by the arrow.
  3. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove the battery screws: 步骤 3 中的图像 1,1
    • Remove the two M2 × L4 mm, flat-head screws.
    • Remove the two M2 × L5 mm, flat-head, screws.
  4. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove the battery: 步骤 4 中的图像 1,1
    • Remove the battery.
结论
To replace the battery & reassemble your device, follow these instructions in reverse order.
另外一个人完成了本指南。
Max Kletskov
于04/22/20注册
40,298 声望
创作了16篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,198篇指南
3条评论
Great Thank you for info
Brad - 回复
Will this battery generate a Bios not authentic battery warning? Other replacement batteries would not charge in my P1 Gen2 ThinkPad.
hello - 回复
Is it compatible for Lenovo Thinkpad P1 Gen1 Type 20MD ?
k2ki - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 72
过去 30 天: 370
总计 11,036
