跳转到主内容
Lenovo ThinkPad L440 Keyboard Replacement
你所需要的
  1. Lenovo ThinkPad L440 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo ThinkPad L440 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo ThinkPad L440 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Open the laptop to access the power button.
    • Hold the power button in the top right until the computer powers off.
    • Turn the computer over so that the bottom of the computer is facing up
  2. Lenovo ThinkPad L440 Keyboard Replacement: 步骤 2 中的图像 1,1
    • On the left side under the raised surface, move the tab to the left towards the unlocked symbol. Repeat this on the right side and move the tab to the right towards the unlocked symbol.
  3. Lenovo ThinkPad L440 Keyboard Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad L440 Keyboard Replacement: 步骤 3 中的图像 2,2
    • From the top of the laptop, slide the raised surface away from the rest of the laptop and out of its slot to remove the battery from the computer.
  4. Lenovo ThinkPad L440 Keyboard Replacement, Keyboard‎: 步骤 4 中的图像 1,3 Lenovo ThinkPad L440 Keyboard Replacement, Keyboard‎: 步骤 4 中的图像 2,3 Lenovo ThinkPad L440 Keyboard Replacement, Keyboard‎: 步骤 4 中的图像 3,3
    • Insert the pointed end of a spudger into the notch on the left side first, and apply gentle pressure upwards until the frame around the keyboard moves up. Repeat for the other side.
    • The spudger used in this guide is NOT ESD-safe, so be cautious when working on your device.
  5. Lenovo ThinkPad L440 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Loosen the six captive screws using a Phillips #00 screwdriver.
  6. Lenovo ThinkPad L440 Keyboard Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad L440 Keyboard Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad L440 Keyboard Replacement: 步骤 6 中的图像 3,3
    • Lift the edge of the keyboard using the blunt side of the spudger, and bring it straight up and out towards you. Lay the keyboard flat on top of the trackpad.
    • Be careful as the keyboard still has ribbon connectors connected to the laptop.
    • To reassemble, gently push down on all sides of the keyboard.
  7. Lenovo ThinkPad L440 Keyboard Replacement: 步骤 7 中的图像 1,3 Lenovo ThinkPad L440 Keyboard Replacement: 步骤 7 中的图像 2,3 Lenovo ThinkPad L440 Keyboard Replacement: 步骤 7 中的图像 3,3
    • Pull the black latch over the connectors up towards the screen with your nail.
    • Grab onto the blue part and, with gentle pressure, pull straight back towards you to release the ribbon cable.
    • Repeat for the second, smaller ribbon connector.
    • These parts are fragile, and can tear easily, so take your time, go gently, and make sure to pull straight towards you.
结论
To reassemble, follow this guide in reverse order. Once completed, power on the laptop and test the new keyboard.
Brendin Melo
于10/18/24注册
109 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-6, Konn Fall 2024 UMass Dartmouth, Team 2-6, Konn Fall 2024 的会员
UMASSD-KONN-F24S2G6
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 62
总计 176
