跳转到主内容
Lenovo ThinkPad Helix Battery Replacement
你所需要的
  1. Lenovo ThinkPad Helix Battery Replacement, Screen: 步骤 1 中的图像 1,1
    • Using a plastic opening tool or opening pick, gently pry the screen off.
    • If possible, use plastic tools to pry the screen, as the metal tool as shown in the image can potentially damage your device.
    • You will need to use a little bit of force to pry it open. There is little indent that goes around the tablet. You will insert your tool between this indent and pry it open.
    • Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
  2. Lenovo ThinkPad Helix Battery Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad Helix Battery Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad Helix Battery Replacement: 步骤 2 中的图像 3,3
    • Lift the screen up slowly.
    • Once separated, you can not fully take it off due to some cable connections.
    • Open the clips of the ZIF connectors and gently grab the cable to pull it out.
  3. Lenovo ThinkPad Helix Battery Replacement: 步骤 3 中的图像 1,1
    • Once the cables are disconnected, remove the screen.
  4. Lenovo ThinkPad Helix Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Using a Phillips #00 screwdriver, unscrew the four nylon-coated 3 mm screws holding the battery in place.
  5. Lenovo ThinkPad Helix Battery Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad Helix Battery Replacement: 步骤 5 中的图像 2,2
    • Disconnect the battery cable from the motherboard.
    • Lift the battery out of the device.
结论
7等其他人完成本指南。
团队
Gateway, Team S1-G6, Saknee Fall 2019 Gateway, Team S1-G6, Saknee Fall 2019 的会员
GCC-SAKNEE-F19S1G6
4 名成员
创作了3篇指南
一条评论
Hi, would you possibly have an explanation as to why a replacement battery is still not charging and yielding error messages? Thank you.
M.H. L. - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 81
总计 6,881
