跳转到主内容
Lenovo ThinkPad HK11e Battery Replacement
你所需要的
  1. Lenovo ThinkPad HK11e Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the Lenovo laptop is shut off.
    • Turn over laptop and lay it on its face exposing the back-plate screws.
  2. Lenovo ThinkPad HK11e Battery Replacement: 步骤 2 中的图像 1,1
    • Find the six screws that hold together the back plate.
    • Carefully unscrew the six 3.3 mm screws that fasten the back plate using the T5 Torx screwdriver.
  3. Lenovo ThinkPad HK11e Battery Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool or a spudger to carefully remove the back plate.
  4. Lenovo ThinkPad HK11e Battery Replacement: 步骤 4 中的图像 1,1
    • Battery is located in the bottom right portion of the laptop.
    • Find the three screws that mount the battery.
    • Carefully unscrew the three 3.5 mm screws that fasten the battery down using the T5 Torx screwdriver.
  5. Lenovo ThinkPad HK11e Battery Replacement: 步骤 5 中的图像 1,1
    • Notice a connector that joins the battery to the laptop.
    • Slowly disconnect the connector by pulling back on the six-wire harness.
  6. Lenovo ThinkPad HK11e Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the battery from its assigned location.
  7. Lenovo ThinkPad HK11e Battery Replacement: 步骤 7 中的图像 1,1
    • Reverse steps to mount new battery correctly.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 37
总计 281
