跳转到主内容
Lenovo ThinkPad Edge E520 RAM Replacement
你所需要的
  1. Lenovo ThinkPad Edge E520 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off and unplug the computer before the start of these steps.
    • Close the laptop lid.
  2. Lenovo ThinkPad Edge E520 RAM Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad Edge E520 RAM Replacement: 步骤 2 中的图像 2,2
    • Flip the computer so that the back is facing upwards.
    • Locate the switch used to release the battery.
    • The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
  3. Lenovo ThinkPad Edge E520 RAM Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad Edge E520 RAM Replacement: 步骤 3 中的图像 2,2
    • Slide the switch towards the unlocked lock icon.
    • While holding it in the unlocked position, slide the battery towards the hinge.
    • Fully separate the battery pack from the back of the laptop.
  4. Lenovo ThinkPad Edge E520 RAM Replacement, Back Plate: 步骤 4 中的图像 1,2 Lenovo ThinkPad Edge E520 RAM Replacement, Back Plate: 步骤 4 中的图像 2,2
    • Flip over the laptop and position it with the battery being furthest away from you.
    • Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
    • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
    • Screw length 6.35 mm, head 3.175 mm
  5. Lenovo ThinkPad Edge E520 RAM Replacement, RAM: 步骤 5 中的图像 1,1
    • The blue tinted rectangular chips will be located opposite of the hinge.
    • They are stacked on top of one another and the second chip will be found underneath the top one.
  6. Lenovo ThinkPad Edge E520 RAM Replacement: 步骤 6 中的图像 1,2 Lenovo ThinkPad Edge E520 RAM Replacement: 步骤 6 中的图像 2,2
    • Locate the two thin metal tracks that hold each RAM in place.
    • Using light pressure, press the tracks outward and the RAM should pop up.
  7. Lenovo ThinkPad Edge E520 RAM Replacement: 步骤 7 中的图像 1,1
    • A light pull on the RAM should remove it with no issues.
    • Repeat from the second step to the third step to remove the second chip.
    • On reassembly, the RAM may provide some difficulty to put it back in. Be patient and slide the ram back in the metal track and apply pressure to make sure that it is in.
    • Be sure that it is in the track so the pins do not bend. A "click" sound may be heard to indicate when it is fully seated.
结论
另外一个人完成了本指南。
Andrew Martin
于03/01/18注册
202 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G2, Simcock Spring 2018 UMass Dartmouth, Team S1-G2, Simcock Spring 2018 的会员
UMASSD-SIMCOCK-S18S1G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 1,002
