跳转到主内容
Lenovo ThinkPad Edge E520 Hard Drive Replacement
你所需要的
  1. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off and unplug the computer before the start of these steps.
    • Close the laptop lid.
  2. Lenovo ThinkPad Edge E520 Hard Drive Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad Edge E520 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Flip the computer so that the back is facing upwards.
    • Locate the switch used to release the battery.
    • The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
  3. Lenovo ThinkPad Edge E520 Hard Drive Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad Edge E520 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Slide the switch towards the unlocked lock icon.
    • While holding it in the unlocked position, slide the battery towards the hinge.
    • Fully separate the battery pack from the back of the laptop.
  4. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Back Plate: 步骤 4 中的图像 1,2 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Back Plate: 步骤 4 中的图像 2,2
    • Flip over the laptop and position it with the battery being furthest away from you.
    • Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
    • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
    • Screw length 6.35 mm, head 3.175 mm
  5. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,3 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,3 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 3,3
    • Position the laptop so that the battery compartment is facing away from you.
    • Remove the two bracket screws on the bottom of the hard drive.
    • Gently lift out the hard drive with its bracket still attached.
    • Remove the bracket from the hard drive.
结论
3等其他人完成本指南。
David Skarbek
于03/01/18注册
271 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G2, Simcock Spring 2018 UMass Dartmouth, Team S1-G2, Simcock Spring 2018 的会员
UMASSD-SIMCOCK-S18S1G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 21
总计 1,431
