简介
This guide will help to replace the front compartment case of the Lenovo Thinkpad Edge E520.
配件
无需配件。
  1. Power off computer before the start of these steps.
    • Power off computer before the start of these steps.
    • Close the computer screen.
  2. Flip the computer so that the back is facing upwards. The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
    • Flip the computer so that the back is facing upwards.
    • The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
  3. Slide the switch towards the unlocked lock icon. While holding it in the unlocked position, slide the battery towards the hinge.
    • Slide the switch towards the unlocked lock icon.
    • While holding it in the unlocked position, slide the battery towards the hinge.
    • Fully separate the battery pack from the back of the laptop.
  4. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Flip over the laptop and position it with the battery being furthest away from you. Remove the four screws on the edges of the T-Shaped plate. Remove the T-Shaped plate from the back of the computer.  It should come off easily if all four aforementioned screws are removed.
    • Flip over the laptop and position it with the battery being furthest away from you.
    • Remove the four screws on the edges of the T-Shaped plate.
    • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
    • Screw length 6.35 mm, head 3.175 mm
  6. There are two screws that have keyboard symbols pointing at them.
    • There are two screws that have keyboard symbols pointing at them.
    • Unscrew the screws with a 3.175 mm diameter and 6.35 mm length with a Phillips head screwdriver.
  7. Turn the laptop back over so that the keyboard is facing you. Use your hands to separate the keyboard from the laptop Use your hands to separate the keyboard from the laptop
    • Turn the laptop back over so that the keyboard is facing you.
    • Use your hands to separate the keyboard from the laptop
  8. Remove all remaining screws on the back of the device.
    • Remove all remaining screws on the back of the device.
    • Screw length 6.35 mm, head 3.175 mm Screws behind battery length 3.175 mm, head 3.175 mm
  9. Flip device back over and open the screen. Insert the prying tool on one edge of the case and follow along all four edges until the case frees up. Remove the case.
    • Flip device back over and open the screen.
    • Insert the prying tool on one edge of the case and follow along all four edges until the case frees up.
    • Remove the case.
结论
另外一个人完成了本指南。
David Skarbek
于2018年03月01日注册
229 信誉积分
创作了3篇指南
团队
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 2
过去的30天: 12
总计 130
