跳转到主内容
Lenovo ThinkPad Edge E520 Back Plate Replacement
你所需要的
  1. Lenovo ThinkPad Edge E520 Back Plate Replacement, Back Plate: 步骤 1 中的图像 1,2 Lenovo ThinkPad Edge E520 Back Plate Replacement, Back Plate: 步骤 1 中的图像 2,2
    • Flip over the laptop and position it with the battery being furthest away from you.
    • Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
    • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
    • Screw length 6.35 mm, head 3.175 mm
结论
另外一个人完成了本指南。
David Skarbek
于03/01/18注册
271 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G2, Simcock Spring 2018 UMass Dartmouth, Team S1-G2, Simcock Spring 2018 的会员
UMASSD-SIMCOCK-S18S1G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 635
