你所需要的
Use a Phillips #0 screwdriver to remove eight M2 × 3 mm screws near the front opening and scattered across the bottom of the laptop.
Remove three M2x3 mm screws using a Phillips #00 screwdriver from the base of the laptop near the opening.
Remove the two M2 x 3mm securing the the optical drive to the device using a Phillips #000 screwdriver.
Unscrew the two M2 x 3mm screws near the hinges using a Phillips #00 screwdriver.
Use a Phillips #000 screwdriver to remove three M2 x 2mm screws from the sides of the motherboard.
即将完成!
结论
