跳转到主内容
Lenovo ThinkPad E570 Wi-Fi Card Replacement
你所需要的
  1. Lenovo ThinkPad E570 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 1 中的图像 1,1
    • Turn the laptop over so that the bottom is facing upwards.
  2. Lenovo ThinkPad E570 Wi-Fi Card Replacement: 步骤 2 中的图像 1,1
    • Unscrew two captive 5 mm screws from the back panel of the laptop using a Phillips #00 screwdriver.
    • Carefully remove the back panel.
  3. Lenovo ThinkPad E570 Wi-Fi Card Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the black and white coaxial cables that are connected to the chip using an opening tool.
  4. Lenovo ThinkPad E570 Wi-Fi Card Replacement: 步骤 4 中的图像 1,1
    • Remove the single 4 mm screw from the Wi-Fi card using a Phillips #0 screwdriver.
  5. Lenovo ThinkPad E570 Wi-Fi Card Replacement: 步骤 5 中的图像 1,1
    • When the screw is removed, the chip will pop up at an angle.
    • Carefully grab the chip and pull outward to remove it from the laptop.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 389
