跳转到主内容
Lenovo ThinkPad E570 CMOS Battery Replacement
你所需要的
  1. Lenovo ThinkPad E570 CMOS Battery Replacement, CMOS Battery: 步骤 1 中的图像 1,3 Lenovo ThinkPad E570 CMOS Battery Replacement, CMOS Battery: 步骤 1 中的图像 2,3 Lenovo ThinkPad E570 CMOS Battery Replacement, CMOS Battery: 步骤 1 中的图像 3,3
    • Turn the laptop over so that the bottom is facing upwards, with the battery facing away from you.
    • Loosen two captive 5 mm screws on the back panel of the laptop using a Phillips #0 screwdriver.
    • Slide the panel towards you, then gently lift up to remove.
  2. Lenovo ThinkPad E570 CMOS Battery Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad E570 CMOS Battery Replacement: 步骤 2 中的图像 2,2
    • Insert the flat end of the halberd spudger underneath the battery to free the it from the adhesive.
    • Unplug the connecting CMOS wire from the motherboard.
    • When reassembling, apply gentle pressure to the new CMOS battery with the adhesive pad facing down.
结论
另外一个人完成了本指南。
Geoffrey Gwin
于07/13/23注册
106 声望
撰写一个指南
团队
IUPUI, Team 1-2, Harley Summer 2023 IUPUI, Team 1-2, Harley Summer 2023 的会员
IUPUI-HARLEY-SU23S1G2
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 231
