跳转到主内容
Lenovo ThinkPad A285 SSD Card Replacement
你所需要的
  1. Lenovo ThinkPad A285 SSD Card Replacement, Back Panel: 步骤 1 中的图像 1,3 Lenovo ThinkPad A285 SSD Card Replacement, Back Panel: 步骤 1 中的图像 2,3 Lenovo ThinkPad A285 SSD Card Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Flip your laptop over so the bottom panel is facing up.
    • Use a Phillips #0 to loosen the 5 screws holding the back panel to the laptop.
    • These screws do not come all the way out, so loosen until free spinning.
    • Lift the bottom of the panel to separate the back panel away from the device.
    • Remove the back panel.
  2. Lenovo ThinkPad A285 SSD Card Replacement, SSD Card: 步骤 2 中的图像 1,3 Lenovo ThinkPad A285 SSD Card Replacement, SSD Card: 步骤 2 中的图像 2,3 Lenovo ThinkPad A285 SSD Card Replacement, SSD Card: 步骤 2 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the 3 mm screw that secures the SSD to the motherboard.
    • Carefully slide the SSD card from its socket to remove it.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Nari Summerlin
于04/09/25注册
123 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 49
总计 309
