跳转到主内容
Lenovo ThinkCentre A70z Backlight Cable Replacement
你所需要的
  1. Lenovo ThinkCentre A70z  Backlight Cable Replacement, Remove Conductive Tape from Backlight Cable: 步骤 1 中的图像 1,1
    • Remove conductive tape wrapped around the backlight cable as below seen below.
    • The issue has a low failure rate with the woven type of conductive tape. However, has a high failure rate with an aluminum foil type of conductive tape.
  2. Lenovo ThinkCentre A70z  Backlight Cable Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkCentre A70z  Backlight Cable Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkCentre A70z  Backlight Cable Replacement: 步骤 2 中的图像 3,3
    • Order special tape that has sponge as noted: 03T9708 34.3BE7.001 FRU_EMI_GASKET_MB_SHEILDING_TOYAMA
    • Replace previous conductive tape with new tape 03T9708 after Removing original tapes.
结论
2等其他人完成本指南。
James Finch
于10/14/17注册
2,268 声望
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 649
