跳转到主内容
Lenovo Tab S8 Power Button Replacement
你所需要的
  1. Lenovo Tab S8 Power Button Replacement, Power Button: 步骤 1 中的图像 1,3 Lenovo Tab S8 Power Button Replacement, Power Button: 步骤 1 中的图像 2,3 Lenovo Tab S8 Power Button Replacement, Power Button: 步骤 1 中的图像 3,3
    • Make sure the device is powered off
    • Gently insert a spudger into one of the bottom corners between the screen and body case. Gently slide the spudger along the inside of the crack to pry the case open
    • Be careful of the small volume and power buttons when prying the case with the spudger. They are connected with small pieces of plastic that break easily.
  2. Lenovo Tab S8 Power Button Replacement: 步骤 2 中的图像 1,3 Lenovo Tab S8 Power Button Replacement: 步骤 2 中的图像 2,3 Lenovo Tab S8 Power Button Replacement: 步骤 2 中的图像 3,3
    • Gently lift the clear-yellow rubber flap from the plastic pegs with a plastic opening tool.
    • The rubber flap secures the button to the casing, and it falls out easily.
结论
James Albu
于08/26/15注册
608 声望
创作了2篇指南
团队
USF Tampa, Team 3-6, Eyestone Fall 2015 USF Tampa, Team 3-6, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S3G6
3 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 2,003
