你所需要的
Gently insert a spudger into one of the bottom corners between the screen and body case.
Slide the spudger along the inside of the crack in order to pry the case open.
在这个步骤中使用的工具:Plastic Cards$2.99
Gently lift the flaps on the four ZIF connectors to disconnect the cables.
Use the plastic card to gently pry the battery from the device.
Use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the cable out from under the camera.
6等其他人完成本指南。
