简介
In this guide, moving the camera is the main focus. Digital cameras themselves are very complex, however, this guide will show you just how easy it is to replace one.
你所需要的
Gently insert a spudger into one of the bottom corners between the screen and body case.
Slide the spudger along the inside of the crack in order to pry the case open.
在这个步骤中使用的工具:Plastic Cards$2.99
Gently lift the flaps on the four ZIF connectors to disconnect the cables.
Use the plastic card to gently pry the battery from the device.
Use a plastic opening tool to gently pry the end of the camera's black ribbon cable (opposite the camera lens) off of the motherboard.
Once the cable is free, use tweezers to pull the camera from the body.
另外一个人完成了本指南。
