跳转到主内容
Lenovo Tab 4 TB-8504F Rear Camera Replacement
你所需要的
  1. Lenovo Tab 4 TB-8504F Rear Camera Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo Tab 4 TB-8504F Rear Camera Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo Tab 4 TB-8504F Rear Camera Replacement, Battery: 步骤 1 中的图像 3,3
    • Start at the microSD slot.
    • Use the opening pick to slide underneath the back cover of the tablet.
    • Slide the opening pick around the tablet until the back cover is off.
  2. Lenovo Tab 4 TB-8504F Rear Camera Replacement: 步骤 2 中的图像 1,3 Lenovo Tab 4 TB-8504F Rear Camera Replacement: 步骤 2 中的图像 2,3 Lenovo Tab 4 TB-8504F Rear Camera Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the 8 screws with a Phillips #000 screwdriver [bit].
    • There is a screw under the blue "s" sticker.
    • Remove tape holding plate down.
    • Use precision tweezers or your fingers to remove plate.
  3. Lenovo Tab 4 TB-8504F Rear Camera Replacement: 步骤 3 中的图像 1,2 Lenovo Tab 4 TB-8504F Rear Camera Replacement: 步骤 3 中的图像 2,2
    • Remove yellow tape.
    • Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
  4. Lenovo Tab 4 TB-8504F Rear Camera Replacement: 步骤 4 中的图像 1,3 Lenovo Tab 4 TB-8504F Rear Camera Replacement: 步骤 4 中的图像 2,3 Lenovo Tab 4 TB-8504F Rear Camera Replacement: 步骤 4 中的图像 3,3
    • Gently pull on the two stretch release adhesive strips. Do not pull up, pull away from battery.
    • Once the tabs are off, lift the battery up from the frame.
    • Do not bend or puncture the battery.
  5. Lenovo Tab 4 TB-8504F Rear Camera Replacement, Rear Camera: 步骤 5 中的图像 1,2 Lenovo Tab 4 TB-8504F Rear Camera Replacement, Rear Camera: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a spudger to lift the rear camera press-fit connector up and free.
    • Use tweezers to lift the rear camera out of the frame.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 550
