当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Place the tablet face down on a soft, stable surface that will protect the screen.
Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
If the seal covering the screw has already been removed, please proceed to the next step in the process.
As the screw is small, you may wish to extract it using a pair of tweezers.
Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
Some force may be required initially to pry the back cover off.
Note that the button tabs for this device are loose inside the case and will fall out when opening.
Using a counterclockwise motion with the Phillips #000 screwdriver, remove the M1.4 × 2.5 screw that holds down the copper strip connected to the battery.
With a pair of Tweezers, carefully unplug the strip connecting the battery to the motherboard.
Working your way around the edge of the battery, pry out the battery using a plastic opening tool
Be aware that the battery is held in by double-sided tape on the underside
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
