跳转到主内容
Lenovo Tab 2 A8 Battery Replacement
你所需要的
  1. Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: 步骤 1 中的图像 1,3 Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: 步骤 1 中的图像 2,3 Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Battery Replacement: 步骤 2 中的图像 1,3 Lenovo Tab 2 A8 Battery Replacement: 步骤 2 中的图像 2,3 Lenovo Tab 2 A8 Battery Replacement: 步骤 2 中的图像 3,3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Battery Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo Tab 2 A8 Battery Replacement, Battery: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using a counterclockwise motion with the Phillips #000 screwdriver, remove the M1.4 × 2.5 screw that holds down the copper strip connected to the battery.
    • With a pair of Tweezers, carefully unplug the strip connecting the battery to the motherboard.
  4. Lenovo Tab 2 A8 Battery Replacement: 步骤 4 中的图像 1,3 Lenovo Tab 2 A8 Battery Replacement: 步骤 4 中的图像 2,3 Lenovo Tab 2 A8 Battery Replacement: 步骤 4 中的图像 3,3
    • Working your way around the edge of the battery, pry out the battery using a plastic opening tool
    • Be aware that the battery is held in by double-sided tape on the underside
结论
5等其他人完成本指南。
2条评论
Thanks... but where do we find a replacement battery?
sebtrudel - 回复
I fixit might have a replacement battery
storm builder - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 69
总计 11,665
