简介
This guide will explain how to remove the back cover and motherboard on your device in order to access the A/V port. This guide will provide detailed steps for replacement of the A/V port.
你所需要的
Place the tablet face down on a soft, stable surface that will protect the screen.
Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
Using the Phillips #000 screwdriver, remove the four M1.4 × 2.5 screws holding the motherboard in place.
Remove the M1.4 × 2.5 screw securing the battery lead to the battery with the Phillips #000 screwdriver.
With a pair of tweezers, gently move the battery lead so it will not obstruct the motherboard.
With a pair of tweezers, carefully unplug the strip connecting the screen to the motherboard.
Flip the motherboard to its back side.
Desolder the six audio/visual port contact points.
Use tweezers to remove the existing audio jack to remove from the motherboard entirely.
另外一个人完成了本指南。
