跳转到主内容
Lenovo Tab 2 A10-70 Power Button Replacement
你所需要的
  1. Lenovo Tab 2 A10-70 Power Button Replacement, Power Button: 步骤 1 中的图像 1,2 Lenovo Tab 2 A10-70 Power Button Replacement, Power Button: 步骤 1 中的图像 2,2
    • Use a plastic opening tool to pry open the back cover of the tablet.
  2. Lenovo Tab 2 A10-70 Power Button Replacement: 步骤 2 中的图像 1,1
    • The power button strip is only held in place by a small piece of double-sided tape.
    • Gently use the precision tweezers to separate the power button strip from the interior frame of the tablet.
  3. Lenovo Tab 2 A10-70 Power Button Replacement: 步骤 3 中的图像 1,1
    • Be careful with the soldering iron to avoid injury.
    • Remove the power button from the motherboard.
    • Use the soldering iron to heat up the connections. Gently pull away from the motherboard after connections are detached.
结论
3等其他人完成本指南。
团队
USF Tampa, Team 12-6, Eyestone Spring 2016 USF Tampa, Team 12-6, Eyestone Spring 2016 的会员
USFT-EYESTONE-S16S12G6
4 名成员
创作了10篇指南
一条评论
Thank you for making this helpfull instrutions.
Where i can get the Buttons?
Simon - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 29
总计 6,748
