跳转到主内容
Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement
你所需要的
  1. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement, Disc Tray Locking Mechanism: 步骤 1 中的图像 1,2 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement, Disc Tray Locking Mechanism: 步骤 1 中的图像 2,2
    • Flip the unit over so that way the bottom is facing you.
    • Remove the two black 7.6mm Phillips #0 screws from the bottom cover.
  2. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 步骤 2 中的图像 1,2 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 步骤 2 中的图像 2,2
    • Use the iFixit Opening Tool to gently pry the unit apart to gain access to the interior.
    • If the top seems stuck, run the iFixit Opening Tool along the edge while simultaneously pulling up on the top with your fingers. Continue to apply pressure until it opens completely.
  3. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 步骤 3 中的图像 1,2 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 步骤 3 中的图像 2,2
    • Open the device tray by inserting a paper clip into the eject hole.
  4. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 步骤 4 中的图像 1,2 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 步骤 4 中的图像 2,2
    • Turn the unit over and remove the two silver 3mm Phillips #0 screws from the aluminum cover.
  5. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 步骤 5 中的图像 1,1
    • Lift the silver coverup to expose the internal components.
    • If the cover seems stuck gently pull up on one edge. The cover should remove completely after one side is free.
  6. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 步骤 6 中的图像 1,2 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 步骤 6 中的图像 2,2
    • Remove the single 3mm Phillips #0 screw.
  7. Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 步骤 7 中的图像 1,2 Lenovo Slim DVD Burner DB65 Disc Tray Locking Mechanism Replacement: 步骤 7 中的图像 2,2
    • Lift and remove the silver tray locking mechanism by detaching the spring which is hooked on the white plastic internal component.
    • Be careful when removing this mechanism—the spring is delicate.
结论
Matthew Green
于07/05/18注册
337 声望
创作了2篇指南
团队
IUPUI, Team S2-G1, Harley Summer 2018 IUPUI, Team S2-G1, Harley Summer 2018 的会员
IUPUI-HARLEY-SU18S2G1
3 名成员
创作了2篇指南
2条评论
Hey there, I tried to fix mine, but 3 tiny black springs came from nowhere, and now I dunno what should I do with them.
RuCharlz - 回复
Me too, i'm stuck
Wassim Ajili -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 1,776
