跳转到主内容
Lenovo S20-30 Keyboard Replacement
你所需要的
  1. Lenovo S20-30 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the Lenovo S20-30 over so that the bottom panel is facing upward.
  2. Lenovo S20-30 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Slide the manual battery latch to the unlock position, so that the red is showing.
  3. Lenovo S20-30 Keyboard Replacement: 步骤 3 中的图像 1,2 Lenovo S20-30 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Slide and hold the spring-loaded battery latch on the other side (right) while sliding the battery out of the computer.
    • Grab new Lenovo S20-30 battery for replacement.
  4. Lenovo S20-30 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,3 Lenovo S20-30 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,3 Lenovo S20-30 Keyboard Replacement, Keyboard: 步骤 4 中的图像 3,3
    • Remove the two front rubber feet using a long metal spudger.
    • Use your Phillips #0 screwdriver to remove the two M2.5 x 5mm flat-head screws located underneath the pads.
  5. Lenovo S20-30 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the nine M2 x 4mm flat head screws located on the outer edges on the back of the laptop.
    • Make sure to keep these screws separated from future screws that will be disassembled throughout this process.
  6. Lenovo S20-30 Keyboard Replacement: 步骤 6 中的图像 1,2 Lenovo S20-30 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Use the long metal spudger to pry open the bottom half of the laptop.
    • Gently lift the cover off to reveal the motherboard.
  7. Lenovo S20-30 Keyboard Replacement: 步骤 7 中的图像 1,2 Lenovo S20-30 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Remove the four M2 x 3mm flat-head screw using a Phillips #000 screwdriver.
  8. Lenovo S20-30 Keyboard Replacement: 步骤 8 中的图像 1,2 Lenovo S20-30 Keyboard Replacement: 步骤 8 中的图像 2,2
    • Flip over laptop and open the lid to have access to the keyboard.
    • Use a plastic opening tool to pry apart the keyboard.
  9. Lenovo S20-30 Keyboard Replacement: 步骤 9 中的图像 1,3 Lenovo S20-30 Keyboard Replacement: 步骤 9 中的图像 2,3 Lenovo S20-30 Keyboard Replacement: 步骤 9 中的图像 3,3
    • A connector is attached to the keyboard.
    • Remove it by gently pulling it outward.
  10. Lenovo S20-30 Keyboard Replacement: 步骤 10 中的图像 1,1
    • Grab replacement keyboard to insert back into place.
结论
3等其他人完成本指南。
ILEANISSE SOTO
于10/01/18注册
187 声望
撰写一个指南
团队
一条评论
where can i find a replacement keyboard/ or what model # do i need?
ed paz - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 18
总计 1,226
