跳转到主内容
Lenovo N23 Chromebook Motherboard Replacement
你所需要的
  1. Lenovo N23 Chromebook Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo N23 Chromebook Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Before starting, make sure that the laptop is powered off and completely unplugged from the charger.
    • Remove the eight 6.0 mm screws holding the back into place using a Phillips #0 screwdriver.
  2. Lenovo N23 Chromebook Motherboard Replacement: 步骤 2 中的图像 1,1
    • Flip the device over.
    • Slide a plastic opening tool between the back cover and keyboard.
    • Carefully pry upwards until you hear a click.
    • Following the seam, slide the opening tool all the way around the front cover, prying upwards occasionally until the keyboard and trackpad are loose from the back cover.
    • Lift the keyboard panel up to reveal the internals.
    • Don't lift the keyboard panel too violently, as there is still a cable attachment to the motherboard.
  3. Lenovo N23 Chromebook Motherboard Replacement: 步骤 3 中的图像 1,3 Lenovo N23 Chromebook Motherboard Replacement: 步骤 3 中的图像 2,3 Lenovo N23 Chromebook Motherboard Replacement: 步骤 3 中的图像 3,3
    • You can now access the internals of the computer.
    • Disconnect the two ribbon cables that connect from the motherboard to the front cover.
    • Using the iFixit opening tool, flip up the black tab holding keyboard ribbon cable and then pull the cable out.
    • Using the opening tool, flip the white tab holding the mouse ribbon cable and then pull the cable out.
  4. Lenovo N23 Chromebook Motherboard Replacement: 步骤 4 中的图像 1,2 Lenovo N23 Chromebook Motherboard Replacement: 步骤 4 中的图像 2,2
    • Lift the keyboard panel from the case and fully remove it from the device.
  5. Lenovo N23 Chromebook Motherboard Replacement: 步骤 5 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the battery in place.
  6. Lenovo N23 Chromebook Motherboard Replacement: 步骤 6 中的图像 1,3 Lenovo N23 Chromebook Motherboard Replacement: 步骤 6 中的图像 2,3 Lenovo N23 Chromebook Motherboard Replacement: 步骤 6 中的图像 3,3
    • Disconnect the battery cable using a plastic opening tool by pulling on the black plastic lip.
    • Lift the battery out of the laptop.
  7. Lenovo N23 Chromebook Motherboard Replacement, Wifi Card: 步骤 7 中的图像 1,3 Lenovo N23 Chromebook Motherboard Replacement, Wifi Card: 步骤 7 中的图像 2,3 Lenovo N23 Chromebook Motherboard Replacement, Wifi Card: 步骤 7 中的图像 3,3
    • Use a plastic opening tool to disconnect the two coaxial cables from the Wi-Fi card.
    • Tuck the two wires out of the way.
  8. Lenovo N23 Chromebook Motherboard Replacement: 步骤 8 中的图像 1,3 Lenovo N23 Chromebook Motherboard Replacement: 步骤 8 中的图像 2,3 Lenovo N23 Chromebook Motherboard Replacement: 步骤 8 中的图像 3,3
    • Remove the single 3.0 mm Phillips #1 screw holding the Wi-Fi card using a Phillips #1 screwdriver.
    • Using your hands, carefully pull the Wi-Fi card sideways out of the port on the motherboard.
  9. Lenovo N23 Chromebook Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,3 Lenovo N23 Chromebook Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,3 Lenovo N23 Chromebook Motherboard Replacement, Motherboard: 步骤 9 中的图像 3,3
    • Remove the USB ribbon cable by lifting up on the white tab using a plastic opening tool and then pulling the cable out.
  10. Lenovo N23 Chromebook Motherboard Replacement: 步骤 10 中的图像 1,2 Lenovo N23 Chromebook Motherboard Replacement: 步骤 10 中的图像 2,2
    • Disconnect the two black connectors on the bottom left side of the motherboard by pulling back on the lip with a plastic opening tool.
  11. Lenovo N23 Chromebook Motherboard Replacement: 步骤 11 中的图像 1,3 Lenovo N23 Chromebook Motherboard Replacement: 步骤 11 中的图像 2,3 Lenovo N23 Chromebook Motherboard Replacement: 步骤 11 中的图像 3,3
    • Disconnect the video cable by lifting upwards on the black tab using a plastic opening tool and pulling the cable out.
  12. Lenovo N23 Chromebook Motherboard Replacement: 步骤 12 中的图像 1,3 Lenovo N23 Chromebook Motherboard Replacement: 步骤 12 中的图像 2,3 Lenovo N23 Chromebook Motherboard Replacement: 步骤 12 中的图像 3,3
    • Remove the five 3.0 mm screws that hold the motherboard in place with a Phillips #0 screwdriver.
    • Lift the motherboard carefully out of the laptop, being sure to not let it get caught on any cables.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 30
总计 1,030
