简介
How to replace the Lenovo N23 Chromebook motherboard
你所需要的
Remove the eight 6.0 mm screws holding the back into place using a Phillips #0 screwdriver.
Flip the device over.
Slide a plastic opening tool between the back cover and keyboard.
Carefully pry upwards until you hear a click.
Following the seam, slide the opening tool all the way around the front cover, prying upwards occasionally until the keyboard and trackpad are loose from the back cover.
Lift the keyboard panel up to reveal the internals.
Disconnect the two ribbon cables that connect from the motherboard to the front cover.
Using the iFixit opening tool, flip up the black tab holding keyboard ribbon cable and then pull the cable out.
Using the opening tool, flip the white tab holding the mouse ribbon cable and then pull the cable out.
Use a plastic opening tool to disconnect the two coaxial cables from the Wi-Fi card.
Tuck the two wires out of the way.
Remove the USB ribbon cable by lifting up on the white tab using a plastic opening tool and then pulling the cable out.
另外一个人完成了本指南。
