跳转到主内容
Lenovo N23 Chromebook LCD Screen Replacement
你所需要的
  1. Lenovo N23 Chromebook LCD Screen Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo N23 Chromebook LCD Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Before starting, make sure that the laptop is powered off and completely unplugged from the charger.
    • Remove the eight 6.0 mm screws holding the back cover into place using a Phillips #0 screwdriver.
  2. Lenovo N23 Chromebook LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Flip the device over.
    • Slide a plastic opening tool between the back cover and keyboard.
    • Carefully pry upwards until you hear a click.
    • Following the seam, slide the opening tool all the way around the front cover, prying upwards occasionally until the keyboard and trackpad are loose from the back cover.
    • Lift the keyboard panel up to reveal the internals.
    • Don't lift the keyboard panel too violently, as there is still a cable attachment to the motherboard.
  3. Lenovo N23 Chromebook LCD Screen Replacement: 步骤 3 中的图像 1,3 Lenovo N23 Chromebook LCD Screen Replacement: 步骤 3 中的图像 2,3 Lenovo N23 Chromebook LCD Screen Replacement: 步骤 3 中的图像 3,3
    • You can now access the internals of the computer.
    • Disconnect the two ribbon cables that connect from the motherboard to the front cover.
    • Using the iFixit opening tool, flip up the black tab holding the keyboard ribbon cable and then pull the cable out.
    • Using the opening tool, flip the white tab holding the mouse ribbon cable and then pull the cable out.
  4. Lenovo N23 Chromebook LCD Screen Replacement: 步骤 4 中的图像 1,2 Lenovo N23 Chromebook LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Lift the keyboard panel from the case and fully remove it from the device.
  5. Lenovo N23 Chromebook LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the battery in place.
  6. Lenovo N23 Chromebook LCD Screen Replacement: 步骤 6 中的图像 1,3 Lenovo N23 Chromebook LCD Screen Replacement: 步骤 6 中的图像 2,3 Lenovo N23 Chromebook LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Disconnect the battery cable using a plastic opening tool by pulling on the black plastic lip.
    • Lift the battery out of the laptop.
  7. Lenovo N23 Chromebook LCD Screen Replacement, LCD Screen: 步骤 7 中的图像 1,3 Lenovo N23 Chromebook LCD Screen Replacement, LCD Screen: 步骤 7 中的图像 2,3 Lenovo N23 Chromebook LCD Screen Replacement, LCD Screen: 步骤 7 中的图像 3,3
    • Remove the two rubber stoppers and two paper covers on the screen bezel using a metal spudger.
    • Remove the four 3.0 mm Phillips #0 screws holding the screen and bezel in place.
  8. Lenovo N23 Chromebook LCD Screen Replacement: 步骤 8 中的图像 1,2 Lenovo N23 Chromebook LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to gently pry upwards on the bezel until a small click can be heard.
    • Do this around the left, top, and right bezels. The bottom bezel is glued in place but can easily be separated by prying as well.
    • Using a plastic opening tool, press firmly at the split of both hinges until a click sound is heard and the two sides of the hinge cover are separated.
  9. Lenovo N23 Chromebook LCD Screen Replacement: 步骤 9 中的图像 1,3 Lenovo N23 Chromebook LCD Screen Replacement: 步骤 9 中的图像 2,3 Lenovo N23 Chromebook LCD Screen Replacement: 步骤 9 中的图像 3,3
    • Using a plastic opening tool, disconnect the video cable connecting the screen to the motherboard.
    • Pull off the bezel to view the screws holding the screen in place.
  10. Lenovo N23 Chromebook LCD Screen Replacement: 步骤 10 中的图像 1,3 Lenovo N23 Chromebook LCD Screen Replacement: 步骤 10 中的图像 2,3 Lenovo N23 Chromebook LCD Screen Replacement: 步骤 10 中的图像 3,3
    • Remove the four 3.0 mm screws holding the screen in place using a Phillips #0 screwdriver.
    • Using an iFixit opening tool, carefully lift the screen from the screen mount bracket and place it facedown where the keyboard would usually rest.
  11. Lenovo N23 Chromebook LCD Screen Replacement: 步骤 11 中的图像 1,3 Lenovo N23 Chromebook LCD Screen Replacement: 步骤 11 中的图像 2,3 Lenovo N23 Chromebook LCD Screen Replacement: 步骤 11 中的图像 3,3
    • Peel back the tape holding the display cable connector in place.
    • Carefully pull backwards on the cable to disconnect it from the screen and lift the screen out of the laptop.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 18
总计 1,242
