简介
This guide will cover the steps needed to remove the speakers. The speakers may need to be removed if the user is experiencing distorted or no audio.
你所需要的
Flip the Chromebook so that the bottom is facing up.
Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
Use a spudger to remove each of the 4 rubber feet.
Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
Flip the Chromebook back over and open the screen.
Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
Separate the battery cable from the motherboard by wedging the edge of a plastic opening tool between the black cable connector and the silver socket on the motherboard.
Pull the battery cable straight towards you, away from the silver socket.
Use the edge of the opening tool to separate the speaker cable connector from the black socket on the motherboard.
Pull the cables towards you and away from the socket.
另外一个人完成了本指南。
