跳转到主内容
Lenovo N22 Chromebook Keyboard Replacement
你所需要的
  1. Lenovo N22 Chromebook Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 Lenovo N22 Chromebook Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 Lenovo N22 Chromebook Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
    • Use a spudger to remove each of the 4 rubber feet.
    • Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
  2. Lenovo N22 Chromebook Keyboard Replacement: 步骤 2 中的图像 1,3 Lenovo N22 Chromebook Keyboard Replacement: 步骤 2 中的图像 2,3 Lenovo N22 Chromebook Keyboard Replacement: 步骤 2 中的图像 3,3
    • Flip the Chromebook back over and open the screen.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
    • It is normal for the tabs to make a loud click when released. The corner tabs will be harder to release than the others and will make a louder click.
  3. Lenovo N22 Chromebook Keyboard Replacement: 步骤 3 中的图像 1,2 Lenovo N22 Chromebook Keyboard Replacement: 步骤 3 中的图像 2,2
    • Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
    • Do not lift the keyboard quickly or you might break the two cables that connect the keyboard to the motherboard.
    • Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N22 Chromebook Keyboard Replacement: 步骤 4 中的图像 1,1
    • Lift the keyboard up and off the back panel, exposing the motherboard and battery.
结论
8等其他人完成本指南。
Jackson Tucker
于04/26/17注册
869 声望
创作了3篇指南
团队
Cal Poly, Team S21-G1, Livingston Spring 2017 Cal Poly, Team S21-G1, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S21G1
4 名成员
创作了14篇指南
6条评论
I have this laptop. The top right corner of the keyboard has popped out. How do I fix this?
Michael Faherty - 回复
Try removing the rubber foot under the popped corner, remove the screw, push down on the corner and replace the screw while holding the corner down.
Craig Carlson -
Just a note: the little rubber feet are all lettered (A-D) and you do need to match them to their proper corners when re-assembling.
Craig Carlson -
I have several keys that have stopped working. Replace the keyboard or is there a fix?
Richard Williams - 回复
This happen when the ribbon cable that connects the keyboard gets squashed too hard.
See [1] below for a decription and fix.
[1] https://forums.lenovo.com/t5/Lenovo-Chro...
Jan -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 58
总计 13,752
