跳转到主内容
Lenovo N22 Chromebook Individual Key Replacement
你所需要的
  1. Lenovo N22 Chromebook Individual Key Replacement, Individual Key: 步骤 1 中的图像 1,1
    • Power down the chromebook before starting this process.
    • Loosen the key by prying on the edge of the key with the plastic opening tool.
  2. Lenovo N22 Chromebook Individual Key Replacement: 步骤 2 中的图像 1,2 Lenovo N22 Chromebook Individual Key Replacement: 步骤 2 中的图像 2,2
    • Remove the key from the keyboard by prying the key off with the opener or with your finger.
    • The key is connected to the keyboard with two connecting plastic squares. One is connected to the keyboard by tabs and one is connected to the keyboard by snaps.
    • When reassembling make sure that the two plastic square connectors are in the same place as when you removed the key.
结论
13等其他人完成本指南。
Jackson Tucker
于04/26/17注册
869 声望
创作了3篇指南
团队
Cal Poly, Team S21-G1, Livingston Spring 2017 Cal Poly, Team S21-G1, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S21G1
4 名成员
创作了14篇指南
6条评论
very vague info. If a Key does not work and I take it out, why should it work once back in?? what do I need to change or look for? seems like very good instructions to take the keys out of a notebook
edperalt - 回复
Where can I order individual keys?
Mallory Montreuil - 回复
He tried to turn it on but it did not work
Clayton Sensing - 回复
I took it off and now it broken he he
BRENNEN FIRKUS - 回复
Yeah so I tried this on my computer to clean my keys and now my alt key won’t go back in. I also got my g key partially stuck in so only the right side of it works. Is there anything I am supposed to do?
Anushka Halepet - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 92
总计 14,395
