跳转到主内容
Lenovo N20p Chromebook WLAN & Bluetooth Replacement
你所需要的
  1. Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Keyboard: 步骤 1 中的图像 1,2 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Power down the Chromebook before starting any repair.
    • Remove the two 3.5 mm Phillips #0 screws using a screwdriver.
    • It is only necessary to remove these two screws to complete this step.
  2. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 2 中的图像 1,2 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 2 中的图像 2,2
    • Use the hook of the metal spudger to carefully lift up the keyboard.
    • Lift the keyboard carefully. If you lift too quickly, it might break the two cables that connect the keyboard to the motherboard.
  3. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 3 中的图像 1,3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 3 中的图像 2,3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 3 中的图像 3,3
    • Carefully, disconnect the keyboard cable from the motherboard carefully by pulling on the blue tab of the cable.
    • You will now be able to replace the keyboard.
  4. Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Battery: 步骤 4 中的图像 1,3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Battery: 步骤 4 中的图像 2,3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Battery: 步骤 4 中的图像 3,3
    • Remove the two rubber feet of the back of the Chromebook using a metal spudger.
    • Remove six bottom 3.5 mm Phillips #0 screws and two top 5 mm Phillips #1 screws.
  5. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 5 中的图像 1,1
    • Remove all nine 3.5 mm Phillips #00 screws using a screwdriver.
  6. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 6 中的图像 1,2 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 6 中的图像 2,2
    • Disconnect the battery cable from the motherboard.
    • Disconnect the touch-pad cable from the motherboard.
  7. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 7 中的图像 1,2 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 7 中的图像 2,2
    • Use the metal spudger along the seam between the keyboard and the bottom of the Chromebook to lift up and remove the palm rest assembly.
    • It is normal for it to click loudly when it is released. Corner tags will be harder to release than other tags and will make a loud sound.
  8. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 8 中的图像 1,3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 8 中的图像 2,3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 8 中的图像 3,3
    • Disconnect the USB cable from the motherboard by pulling the blue tab out of the cable.
    • Remove all five 3.0 mm Phillips #00 screws which connect the battery and motherboard.
  9. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 9 中的图像 1,2 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 9 中的图像 2,2
    • Remove the battery.
    • It is helpful to lift and hold the battery as shown.
  10. Lenovo N20p Chromebook WLAN & Bluetooth Replacement, WLAN & Bluetooth: 步骤 10 中的图像 1,3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, WLAN & Bluetooth: 步骤 10 中的图像 2,3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, WLAN & Bluetooth: 步骤 10 中的图像 3,3
    • Disconnect the white and black cables from the WLAN & Bluetooth combo.
    • Remove the 2 mm Phillips #1 screw.
    • Lift and pull the WLAN & Bluetooth in the direction shown.
  11. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: 步骤 11 中的图像 1,1
    • You will now be able to replace the WLAN & Bluetooth combo module.
结论
Shihao Cao
于07/12/18注册
497 声望
创作了4篇指南
团队
UW Tacoma, Team S1-G2, Cardinal Summer 2018 UW Tacoma, Team S1-G2, Cardinal Summer 2018 的会员
UWT-CARDINAL-SU18S1G2
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 12
总计 208
