跳转到主内容
Lenovo N20p Chromebook Keyboard Replacement
你所需要的
  1. Lenovo N20p Chromebook Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Lenovo N20p Chromebook Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Power down the Chromebook before starting any repair.
    • Remove the two 3.5 mm Phillips #0 screws using a screwdriver.
    • It is only necessary to remove these two screws to complete this step.
  2. Lenovo N20p Chromebook Keyboard Replacement: 步骤 2 中的图像 1,2 Lenovo N20p Chromebook Keyboard Replacement: 步骤 2 中的图像 2,2
    • Use the hook of the metal spudger to carefully lift up the keyboard.
    • Lift the keyboard carefully. If you lift too quickly, it might break the two cables that connect the keyboard to the motherboard.
  3. Lenovo N20p Chromebook Keyboard Replacement: 步骤 3 中的图像 1,3 Lenovo N20p Chromebook Keyboard Replacement: 步骤 3 中的图像 2,3 Lenovo N20p Chromebook Keyboard Replacement: 步骤 3 中的图像 3,3
    • Carefully, disconnect the keyboard cable from the motherboard carefully by pulling on the blue tab of the cable.
    • You will now be able to replace the keyboard.
结论
Shihao Cao
于07/12/18注册
497 声望
创作了4篇指南
团队
UW Tacoma, Team S1-G2, Cardinal Summer 2018 UW Tacoma, Team S1-G2, Cardinal Summer 2018 的会员
UWT-CARDINAL-SU18S1G2
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 12
总计 276
