跳转到主内容
Lenovo Miix 2 Battery Replacement
你所需要的
  1. Lenovo Miix 2 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo Miix 2 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Battery Replacement: 步骤 2 中的图像 1,2 Lenovo Miix 2 Battery Replacement: 步骤 2 中的图像 2,2
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Battery Replacement: 步骤 3 中的图像 1,2 Lenovo Miix 2 Battery Replacement: 步骤 3 中的图像 2,2
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Battery Replacement: 步骤 4 中的图像 1,2 Lenovo Miix 2 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the battery by prying up with your fingers or a plastic opening tool.
结论
3等其他人完成本指南。
团队
Cal Poly, Team 5-8, Maness Spring 2015 Cal Poly, Team 5-8, Maness Spring 2015 的会员
CPSU-MANESS-S15S5G8
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 29
总计 8,983
