跳转到主内容
Lenovo Legion Y530-15ICH USB Port Replacement
你所需要的
  1. Lenovo Legion Y530-15ICH USB Port Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH USB Port Replacement: 步骤 2 中的图像 1,2 Lenovo Legion Y530-15ICH USB Port Replacement: 步骤 2 中的图像 2,2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH USB Port Replacement, USB Port: 步骤 3 中的图像 1,2 Lenovo Legion Y530-15ICH USB Port Replacement, USB Port: 步骤 3 中的图像 2,2
    • Remove the ribbon cable connecting the USB port to the motherboard, located adjacent to the fan unit.
    • Using a JIS #1 screwdriver, remove the two screws securing the USB port to the module.
  4. Lenovo Legion Y530-15ICH USB Port Replacement: 步骤 4 中的图像 1,1
    • Gently disconnect the single ribbon cable with your fingers.
    • Remove the USB port from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 944
