跳转到主内容
Lenovo Legion Y530-15ICH Solid State Drive Replacement
你所需要的
  1. Lenovo Legion Y530-15ICH Solid State Drive Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH Solid State Drive Replacement: 步骤 2 中的图像 1,2 Lenovo Legion Y530-15ICH Solid State Drive Replacement: 步骤 2 中的图像 2,2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Solid State Drive Replacement, Solid State Drive: 步骤 3 中的图像 1,2 Lenovo Legion Y530-15ICH Solid State Drive Replacement, Solid State Drive: 步骤 3 中的图像 2,2
    • Do not remove the thermal pad.
    • Remove one 4mm screw circled in orange in the second picture with a JIS #1 screwdriver.
  4. Lenovo Legion Y530-15ICH Solid State Drive Replacement: 步骤 4 中的图像 1,2 Lenovo Legion Y530-15ICH Solid State Drive Replacement: 步骤 4 中的图像 2,2
    • Carefully remove the SSD from its connector.
结论
Insert your new SSD into the connector. To reassemble your device, follow these instructions in reverse order.
另外一个人完成了本指南。
Kaylie Klausing
于02/07/20注册
743 声望
创作了6篇指南
团队
Cal Poly, Team S7-G1, Regan Winter 2020 Cal Poly, Team S7-G1, Regan Winter 2020 的会员
CPSU-REGAN-W20S7G1
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 125
总计 3,641
