简介
The motherboard acts as the central hub of communication between all of the components in your device. If random applications are quitting or if you’re seeing the “blue screen of death” (BSoD), it may be time to replace the motherboard in your computer. This guide will go through the steps on how to replace the motherboard of the Lenovo Legion Y530-15ICH.
你所需要的
Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
Five 7 mm screws
Six 4 mm screws
Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
Remove one 4mm screw circled in orange in the second picture with a JIS #1 screwdriver.
Start by disconnecting the ribbon cable that is near the audio driver. It is recommended to use the iFixit Opening Pick to remove the ribbon cable.
4等其他人完成本指南。
3条评论
Kaylie Klausing
I hope you burn in !&&*
Safwat Ali - 回复
You fckking piece of $@$*.
DON'T FOLLOW THIS.
FCKKKK YOUUUUU
Safwat Ali - 回复
What the hell is wrong with this guy?
