跳转到主内容
Lenovo Legion Y530-15ICH Fan Replacement
你所需要的
  1. Lenovo Legion Y530-15ICH Fan Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH Fan Replacement: 步骤 2 中的图像 1,2 Lenovo Legion Y530-15ICH Fan Replacement: 步骤 2 中的图像 2,2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Fan Replacement, Fan: 步骤 3 中的图像 1,2 Lenovo Legion Y530-15ICH Fan Replacement, Fan: 步骤 3 中的图像 2,2
    • Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
    • Remove the plastic covering after the screws have been loosened.
    • Spring screws will stay attached to the cover.
  4. Lenovo Legion Y530-15ICH Fan Replacement: 步骤 4 中的图像 1,1
    • Use a JIS #1 screwdriver to remove four 4mm screws securing the fans to the device.
  5. Lenovo Legion Y530-15ICH Fan Replacement: 步骤 5 中的图像 1,1
    • Unplug the wires connecting the two fans to the motherboard.
    • When doing this, tug carefully from side to side.
  6. Lenovo Legion Y530-15ICH Fan Replacement: 步骤 6 中的图像 1,2 Lenovo Legion Y530-15ICH Fan Replacement: 步骤 6 中的图像 2,2
    • Lift the fans out of their positions and remove them from the device.
结论
4等其他人完成本指南。
Kaylie Klausing
于02/07/20注册
743 声望
创作了6篇指南
团队
Cal Poly, Team S7-G1, Regan Winter 2020 Cal Poly, Team S7-G1, Regan Winter 2020 的会员
CPSU-REGAN-W20S7G1
4 名成员
创作了11篇指南
4条评论
Thank you! Very clear and well photographed :)
Daniel Perez - 回复
Any recommended stores for the replacement fans?
Ivan Ramljak - 回复
Worked like a charm, thank you!!
Skyler Boyle - 回复
where can i get a good replacement please
peters pelumi - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 76
过去 30 天: 326
总计 8,480
