跳转到主内容
你所需要的
  1. Lenovo Legion Y530-15ICH Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH Battery Replacement: 步骤 2 中的图像 1,2 Lenovo Legion Y530-15ICH Battery Replacement: 步骤 2 中的图像 2,2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
  4. Lenovo Legion Y530-15ICH Battery Replacement: 步骤 4 中的图像 1,2 Lenovo Legion Y530-15ICH Battery Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Now you can safely remove the battery.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
8等其他人完成本指南。
Kaylie Klausing
于2020年02月07日注册
743 声望
创作了6篇指南
团队
Cal Poly, Team S7-G1, Regan Winter 2020 Cal Poly, Team S7-G1, Regan Winter 2020 的会员
CPSU-REGAN-W20S7G1
4 名成员
创作了11篇指南
2条评论
Hello! I have a Lenovo Y530 laptop and its battery is swollen. After removing the battery and waiting for the replacement, can I directly plug in the laptop to the power without having the battery?
Joshua Luna - 回复
Hi Joshua,
Yes! Be careful to reassemble everything other than the laptop. The laptop should boot, though depending on the brand and model, some will refuse without a battery.
Arthur Shi -
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 96
过去 30 天: 492
总计 11,297
