跳转到主内容
Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement
你所需要的
  1. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement, Base Panel: 步骤 1 中的图像 1,1
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement, Wi-Fi  Card: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
  4. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement: 步骤 4 中的图像 1,1
    • Pull the Wi-Fi card directly out of its port.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 444
