跳转到主内容
Lenovo Legion Y520-15IKBN Hard Drive Replacement
你所需要的
  1. Lenovo Legion Y520-15IKBN Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 Lenovo Legion Y520-15IKBN Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Remove the thirteen 6.5 mm screws from the bottom of the laptop using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop on its side and use a spudger or a credit card to pry the bottom covering off. To get a better grip you may want to open the laptop slightly.
    • The bottom piece will make popping noises as it is pulled from the laptop.
    • When reassembling make sure that the bottom piece clicks back into place on all sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Hard Drive Replacement: 步骤 3 中的图像 1,3 Lenovo Legion Y520-15IKBN Hard Drive Replacement: 步骤 3 中的图像 2,3 Lenovo Legion Y520-15IKBN Hard Drive Replacement: 步骤 3 中的图像 3,3
    • The hard drive is a white square located on the right side of your device.
    • Use a Phillips #00 screwdriver to remove four 4.0 mm screws holding the hard drive in place.
  4. Lenovo Legion Y520-15IKBN Hard Drive Replacement: 步骤 4 中的图像 1,2 Lenovo Legion Y520-15IKBN Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Slide the hard drive from the device towards your right.
    • When reinstalling remember to slide the hard drive in from the right. Don't try to force it in from the front.
结论
8等其他人完成本指南。
一条评论
Hi,
does anyone know if replacing the 1TB hard disk with a 1TB SSD is possible? (I’m thinking in terms of cloning the whole disk: can I go for a 1TB SSD or do I need a bigger one? Do hidden partitions for restoring the system / this kind of stuff get copied correctly? Most tutorials online just copy the Windows partition: wouldn’t want to find out I can’t reset the system if needed.)
Cycy - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 26
过去 30 天: 119
总计 10,721
