跳转到主内容
Lenovo Legion Y520-15IKBN Fan Replacement
你所需要的
  1. Lenovo Legion Y520-15IKBN Fan Replacement, Base Panel: 步骤 1 中的图像 1,1
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Fan Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Fan Replacement, Fan: 步骤 3 中的图像 1,3 Lenovo Legion Y520-15IKBN Fan Replacement, Fan: 步骤 3 中的图像 2,3 Lenovo Legion Y520-15IKBN Fan Replacement, Fan: 步骤 3 中的图像 3,3
    • There is a piece of plastic covering part of the RAM and the fan. You will need to remove this to get to the fan.
    • Unplug the battery then, you will need to remove the four 4mm screws around the fan using a Phillips #00 screwdriver.
  4. Lenovo Legion Y520-15IKBN Fan Replacement: 步骤 4 中的图像 1,3 Lenovo Legion Y520-15IKBN Fan Replacement: 步骤 4 中的图像 2,3 Lenovo Legion Y520-15IKBN Fan Replacement: 步骤 4 中的图像 3,3
    • Unscrew all the screws then unplug the wires connected to the fan.
    • Once all the wires are unplugged from the fan, move the wires aside to get the fan.
  5. Lenovo Legion Y520-15IKBN Fan Replacement: 步骤 5 中的图像 1,3 Lenovo Legion Y520-15IKBN Fan Replacement: 步骤 5 中的图像 2,3 Lenovo Legion Y520-15IKBN Fan Replacement: 步骤 5 中的图像 3,3
    • Lift the fan out of the laptop body.
结论
9等其他人完成本指南。
3条评论
Superb guide. thank you random citizen for creating this guide
Fikri Nur Nafi - 回复
Do I need to remove the fan if I want to clean it or add oil?
Ziro Hutt - 回复
Is there a way to open the fan to clean the dust from the blade ?
Apalagi08 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 53
总计 7,016
