跳转到主内容
Lenovo Legion 5-15ACH6 SSD Replacement
你所需要的
  1. Lenovo Legion 5-15ACH6 SSD Replacement, SSD: 步骤 1 中的图像 1,1
    • Prepare your work area on a flat surface.
    • Lay your laptop down with the back case facing up.
  2. Lenovo Legion 5-15ACH6 SSD Replacement: 步骤 2 中的图像 1,1
    • Use a Philips #1 screwdriver to remove the six 11.1 mm on the back of the device.
    • Use a Philips #00 screwdriver to remove the four 4.1 mm screws on the back case.
  3. Lenovo Legion 5-15ACH6 SSD Replacement: 步骤 3 中的图像 1,3 Lenovo Legion 5-15ACH6 SSD Replacement: 步骤 3 中的图像 2,3 Lenovo Legion 5-15ACH6 SSD Replacement: 步骤 3 中的图像 3,3
    • Starting from the back of the laptop slide your opening tool between the bottom cover and laptop chassis.
    • Run the opening tool along the seam to separate the bottom cover from the chassis.
    • Remove the bottom cover and place to the side.
  4. Lenovo Legion 5-15ACH6 SSD Replacement: 步骤 4 中的图像 1,3 Lenovo Legion 5-15ACH6 SSD Replacement: 步骤 4 中的图像 2,3 Lenovo Legion 5-15ACH6 SSD Replacement: 步骤 4 中的图像 3,3
    • To disconnect the battery cable safely, use the pointed tip of a spudger to carefully push on each side of the connector.
    • Alternating from one side to the other, gently “walk” the connector out of its socket.
    • Always pull cables by their connectors and not the wires themselves.
    • Touching any electrical component with the battery plugged in can result in damage to the motherboard.
  5. Lenovo Legion 5-15ACH6 SSD Replacement: 步骤 5 中的图像 1,2 Lenovo Legion 5-15ACH6 SSD Replacement: 步骤 5 中的图像 2,2
    • Remove the three 4.1mm Phillips #00 screws holding the metal shield in place.
    • Remove the metal shield and place it to the side.
  6. Lenovo Legion 5-15ACH6 SSD Replacement: 步骤 6 中的图像 1,1
    • Remove the single 4.1 mm Philips #00 screw holding the SSD in place.
    • Pull the SSD out and away from the socket.
结论
3等其他人完成本指南。
团队
CSU Los Angeles, Team 12-5, Ribeiro Fall 2023 CSU Los Angeles, Team 12-5, Ribeiro Fall 2023 的会员
CSULA-RIBEIRO-F23S12G5
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 92
总计 461
