跳转到主内容
Lenovo Laptop T400 Motherboard Replacement
你所需要的
  1. Lenovo Laptop T400 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • recommend to print out picture of the backside of the laptop and then use it as a template to place the screws on. They are many and different sizes.
    • Remove all bottom screws and place on template printout.
  2. Lenovo Laptop T400 Motherboard Replacement: 步骤 2 中的图像 1,2 Lenovo Laptop T400 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove DVD drive. Toggle the "play triangle" switch so that the tab extends. Pull the tab to remove the DVD drive.
    • Remove hard drive
  3. Lenovo Laptop T400 Motherboard Replacement: 步骤 3 中的图像 1,3 Lenovo Laptop T400 Motherboard Replacement: 步骤 3 中的图像 2,3 Lenovo Laptop T400 Motherboard Replacement: 步骤 3 中的图像 3,3
    • unsnap touchpad left and right.
    • lift up touchpad carefully, and disconnect touchpad.
  4. Lenovo Laptop T400 Motherboard Replacement: 步骤 4 中的图像 1,2 Lenovo Laptop T400 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Pull keyboard gently toward yourself. and then lift up untill flex is visible.
    • use spudger to disconnect connector for keyboard.
  5. Lenovo Laptop T400 Motherboard Replacement: 步骤 5 中的图像 1,1
    • The rest of the guide is mosly helpfull pictures...
    • Remove WLAN module by
    • unplug carefully with spudger the two RF connectors to WLAN module.
    • remove the two screws holding wlan module.
    • lift up module 45 degress and pull outwards.
  6. Lenovo Laptop T400 Motherboard Replacement: 步骤 6 中的图像 1,3 Lenovo Laptop T400 Motherboard Replacement: 步骤 6 中的图像 2,3 Lenovo Laptop T400 Motherboard Replacement: 步骤 6 中的图像 3,3
    • usefull images showing most of main assembly.
    • Removing RAM modules is usefull if the whole logic board needs to be taken out.
    • From here on , unscrew everything - carefully note where screws belong. I used Ifixit magnetic mat and some note making.
  7. Lenovo Laptop T400 Motherboard Replacement: 步骤 7 中的图像 1,1
    • one more image to help you
结论
8等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 52
总计 12,129
