简介
This guide shows a step by step process on how to replace the front camera on a Lenovo Ideatab S6000. The front camera would need to be replaced if the front camera function is not working properly on the tablet. If the screen is cracked or shattered, be sure to wear proper protective equipment and make sure device is turned off before any repair is started.
你所需要的
Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a spudger.
另外一个人完成了本指南。
