跳转到主内容
Lenovo Ideatab A1107 Back Cover Replacement
你所需要的
  1. Lenovo Ideatab A1107 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,2 Lenovo Ideatab A1107 Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Insert a plastic opener in-between the black back panel and the silver body of the tablet.
    • Use the plastic opener to pry the back panel off by moving the plastic opener around the outside edge of the device.
  2. Lenovo Ideatab A1107 Back Cover Replacement: 步骤 2 中的图像 1,2 Lenovo Ideatab A1107 Back Cover Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the seventeen 4mm screws.
  3. Lenovo Ideatab A1107 Back Cover Replacement: 步骤 3 中的图像 1,1
    • Lift up and remove the interior casing to expose the inner components.
    • Do not be alarmed if the volume button and lock button fall off when removing the interior casing.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 440
