跳转到主内容
Lenovo Ideapad S415 Touch Fan Replacement
你所需要的
  1. Lenovo Ideapad S415 Touch Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Fan Replacement: 步骤 2 中的图像 1,1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Fan Replacement: 步骤 3 中的图像 1,1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Fan Replacement: 步骤 4 中的图像 1,1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Fan Replacement: 步骤 5 中的图像 1,1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch Fan Replacement, Fan: 步骤 6 中的图像 1,2 Lenovo Ideapad S415 Touch Fan Replacement, Fan: 步骤 6 中的图像 2,2
    • Locate the five 6mm black screws on the bottom.
    • Using a Phillips #0 screwdriver, remove all five black screws.
  7. Lenovo Ideapad S415 Touch Fan Replacement: 步骤 7 中的图像 1,2 Lenovo Ideapad S415 Touch Fan Replacement: 步骤 7 中的图像 2,2
    • Locate the three 4mm silver screws on the bottom area where the battery was removed.
    • Using the Phillips #0 screwdriver, remove all three silver screws.
  8. Lenovo Ideapad S415 Touch Fan Replacement: 步骤 8 中的图像 1,3 Lenovo Ideapad S415 Touch Fan Replacement: 步骤 8 中的图像 2,3 Lenovo Ideapad S415 Touch Fan Replacement: 步骤 8 中的图像 3,3
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stoppers by lifting each with your fingers.
  9. Lenovo Ideapad S415 Touch Fan Replacement: 步骤 9 中的图像 1,3 Lenovo Ideapad S415 Touch Fan Replacement: 步骤 9 中的图像 2,3 Lenovo Ideapad S415 Touch Fan Replacement: 步骤 9 中的图像 3,3
    • Under each of the four stoppers, there will be a 6mm screw.
    • Use the Phillips #0 screwdriver to remove all four screws.
  10. Lenovo Ideapad S415 Touch Fan Replacement: 步骤 10 中的图像 1,2 Lenovo Ideapad S415 Touch Fan Replacement: 步骤 10 中的图像 2,2
    • Carefully open up the laptop to reveal the internal components.
  11. Lenovo Ideapad S415 Touch Fan Replacement: 步骤 11 中的图像 1,2 Lenovo Ideapad S415 Touch Fan Replacement: 步骤 11 中的图像 2,2
    • Locate the silver 6mm screw on the top of the fan
    • Locate the silver 4mm screw on the bottom of the fan
    • Use a Phillips #0 screwdriver to remove both screws.
  12. Lenovo Ideapad S415 Touch Fan Replacement: 步骤 12 中的图像 1,2 Lenovo Ideapad S415 Touch Fan Replacement: 步骤 12 中的图像 2,2
    • Locate the fan power connector.
    • Use a spudger or your hands to disconnect the fan power connector from its port.
  13. Lenovo Ideapad S415 Touch Fan Replacement: 步骤 13 中的图像 1,2 Lenovo Ideapad S415 Touch Fan Replacement: 步骤 13 中的图像 2,2
    • Once the fan power connector is disconnected, lift up the bronze heatsink and pull the wires out from underneath it.
    • Lift up the fan and pull free.
结论
Alexandria
于02/05/19注册
363 声望
创作了2篇指南
团队
UC Davis, Team S20-G5, Lore Winter 2019 UC Davis, Team S20-G5, Lore Winter 2019 的会员
UCD-LORE-W19S20G5
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 184
