跳转到主内容
Lenovo Ideapad Flex 4-1570 Touchpad Replacement
你所需要的
  1. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 步骤 2 中的图像 1,1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Battery: 步骤 4 中的图像 1,2 Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Battery: 步骤 4 中的图像 2,2
    • Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery.
    • Do not pry or pull on the socket itself or you risk damaging the motherboard.
  5. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 步骤 5 中的图像 1,1
    • Remove the three 4 mm screws using a T5 Torx Screwdriver.
  6. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 步骤 6 中的图像 1,1
    • Remove the battery.
  7. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Touchpad: 步骤 7 中的图像 1,1
    • Locate the touch pad and remove the two 3 mm screws using a T5 Torx Screwdriver.
  8. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 步骤 8 中的图像 1,1
    • Disconnect the touch pad chip from the motherboard.
  9. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 步骤 9 中的图像 1,1
    • Disconnect the bronze piece of tape from touch pad and set it off to the side.
  10. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 步骤 10 中的图像 1,2 Lenovo Ideapad Flex 4-1570 Touchpad Replacement: 步骤 10 中的图像 2,2
    • Open the laptop and, with the assistance of the iFixit blue plastic tool, guide the touch pad through, it should come out on its own.
结论
Isaiah Vang
于10/04/18注册
669 声望
创作了6篇指南
团队
UW Stout, Team S6-G6, Ogden Fall 2018 UW Stout, Team S6-G6, Ogden Fall 2018 的会员
UWSTOUT-OGDEN-F18S6G6
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 19
总计 558
