跳转到主内容
Lenovo Ideapad Flex 4-1570 Speakers Replacement
你所需要的
  1. Lenovo Ideapad Flex 4-1570 Speakers Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Speakers Replacement: 步骤 2 中的图像 1,1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Speakers Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Speakers Replacement, Speakers: 步骤 4 中的图像 1,2 Lenovo Ideapad Flex 4-1570 Speakers Replacement, Speakers: 步骤 4 中的图像 2,2
    • Lift up on each speaker, one by one. The speaker should lift up with ease.
  5. Lenovo Ideapad Flex 4-1570 Speakers Replacement: 步骤 5 中的图像 1,2 Lenovo Ideapad Flex 4-1570 Speakers Replacement: 步骤 5 中的图像 2,2
    • Unwind the speaker wire from the plastic brackets. Once you have the wire completely unwinded, use two blue iFixit tools to disconnect the speaker chip from the motherboard.
结论
Isaiah Vang
于10/04/18注册
669 声望
创作了6篇指南
团队
UW Stout, Team S6-G6, Ogden Fall 2018 UW Stout, Team S6-G6, Ogden Fall 2018 的会员
UWSTOUT-OGDEN-F18S6G6
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 202
