跳转到主内容
简介
If your Lenovo’s Ideapad Flex 4 battery cannot hold a charge, and your laptop dies if not plugged in, use this guide to replace your battery.
  1. Turn off your laptop before you begin.
    • Turn off your laptop before you begin.
  2. Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. After all of the screws are removed, use a plastic opening tool to carefully pry the black cover off.
    • After all of the screws are removed, use a plastic opening tool to carefully pry the black cover off.
    • Remove the back cover.
  4. Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery. Do not pry or pull on the socket itself or you risk damaging the motherboard.
    • Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery.
    • Do not pry or pull on the socket itself or you risk damaging the motherboard.
  5. Remove the three 4 mm screws using a T5 Torx Screwdriver.
    • Remove the three 4 mm screws using a T5 Torx Screwdriver.
  6. Remove the battery.
    • Remove the battery.
结论
2等其他人完成本指南。
Isaiah Vang
于2018年10月04日注册
645 信誉积分
创作了6篇指南
团队
UW Stout, Team S6-G6, Ogden Fall 2018 UW Stout, Team S6-G6, Ogden Fall 2018 的会员
UWSTOUT-OGDEN-F18S6G6
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 22
总计 755
