跳转到主内容
Lenovo Ideapad Flex 15 RAM Replacement
你所需要的
  1. Lenovo Ideapad Flex 15 RAM Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Lenovo Ideapad Flex 15 RAM Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 RAM Replacement: 步骤 2 中的图像 1,2 Lenovo Ideapad Flex 15 RAM Replacement: 步骤 2 中的图像 2,2
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 RAM Replacement: 步骤 3 中的图像 1,3 Lenovo Ideapad Flex 15 RAM Replacement: 步骤 3 中的图像 2,3 Lenovo Ideapad Flex 15 RAM Replacement: 步骤 3 中的图像 3,3
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 RAM Replacement: 步骤 4 中的图像 1,1
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 RAM Replacement: 步骤 5 中的图像 1,3 Lenovo Ideapad Flex 15 RAM Replacement: 步骤 5 中的图像 2,3 Lenovo Ideapad Flex 15 RAM Replacement: 步骤 5 中的图像 3,3
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 RAM Replacement: 步骤 6 中的图像 1,2 Lenovo Ideapad Flex 15 RAM Replacement: 步骤 6 中的图像 2,2
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
  7. Lenovo Ideapad Flex 15 RAM Replacement, RAM: 步骤 7 中的图像 1,2 Lenovo Ideapad Flex 15 RAM Replacement, RAM: 步骤 7 中的图像 2,2
    • Once open, locate the RAM stick below the fan on the bottom right corner of the Flex 15.
    • At the same time, using two hands, pull both clips away from the RAM module.
  8. Lenovo Ideapad Flex 15 RAM Replacement: 步骤 8 中的图像 1,2 Lenovo Ideapad Flex 15 RAM Replacement: 步骤 8 中的图像 2,2
    • The RAM stick should start to tilt upwards. Once you see this, pull the stick diagonally towards the top of the laptop.
    • Be careful and do not apply extra pressure on the RAM.
    • If you feel that it will snap, pull the clips apart farther to loosen the RAM connection. Then try again.
结论
3等其他人完成本指南。
Brent
于03/04/16注册
804 声望
创作了6篇指南
团队
UMass Dartmouth, Team 6-6, Bhusal Spring 2016 UMass Dartmouth, Team 6-6, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S6G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 3,039
